Purchased new 2014 Mazda 6 with clear coated wheels. Purchased wheel cleaner (Sonex). Wheels clean up fine but wondering if really just soap and water work just as well? I find even with wheel cleaner I cannot just hose off. I still need to use microfiber to get dirt off. Seems like soap and water does same job and costs less. What am I missing here? Maybe because wheels are new?
Best thing you can do is to,
"Find something you like and use it often"
My guess is this is a daily driver?
As such, the wheels will get dirty with two things,
- Brake dust
- Road Grime or road film
The best thing you can do to keep your wheels clean is to clean them often and to do this without causing harm to the clear coat finish is to protect them with a product that will act as a
Sacrificial Barrier Coating
That is a product that will sacrifice itself so your wheel's clear coat wont' have to give itself up.
Coatings are an option as they form a strong bond to the wheel surface and resist breaking down from exposure to heat. I just coated my wheels with the new Black Label Wheel Coating and my wheels are also painted but not with clear paint but single stage black paint. (same idea).
Should help to make make cleaning the wheels faster and easier. Since I coat my tires with TUF SHINE I only use my car wash soap to clean my tires and hopefully now my wheels.
My truck does have 4-wheel disc brakes so I do have brake dust accumulation at all 4 corners and since it's been raining a lot here in South Florida I also have road film issues all over the truck.
See this article as it explains
where road film comes from...
Road Film - If you drive your car in the rain your car has road film
If you want to keep your clearcoated wheels looking nice then definitley find something you like in both a protectant and a wash and use it often...
:xyxthumbs:
