Wheels embedded with rust bits
Vlad
Hello,
Been reading some forums that wheel brightener, Sonax, and Iron X is pretty good at heavy brake dust. However my situation is that this wheel had worn pads and was metal to metal. All these bits engraved themselves on the wheels. So far I have tried Griot's Heavy Duty cleaner which turns purple/red each time I spray on it but hardly affects it. I've also tried claying but there is way too much of this rust bits to get it off by clay alone.
Any tips? View attachment 54641View attachment 54642
Sent from my XT1650 using Autogeekonline mobile app
Iron X, Rupes or Soxax wheel cleaner. Agitate it with a brush. It will take more than one application.
Why not continue with the Griots HD wheel cleaner. Isn't basically the same chemistry, maybe just a little weaker?
Griots wheel cleaner was hardly making a dent in rust bits. I was hitting it 5 times with very little improvement after rubbing and agitating. You are right that is similar chemistry but it most certainly isn't touch free wash like Sonax can be. I'll have to see, Sonax comes in Wednesday.
I have had success with Iron X removing similar brake deposits. Like others have said, it took applying Iron X, allowing a full dwell time, agitating with a brush, rinsing to check progress, and repeating the process until I achieved the desired results.
I was thinking about trying to order the IronX Paste from another site. AG used to carry it, but it seems they no longer will. Then I though about how much Jeff (GSKR) said he likes their Snow Soap so I decided to look into it a little.
If you read the info on CarProUSA site, Snow Soap can be used a couple of different ways. Not just as a snow "foam" as I commonly thought it was. It seems you can use straight similar to the paste application.
When creating Iron-X Snow Soap, we imagined the time that could be saved by combining the iron-fallout removing power of Iron-X, with the cleaning and lubricating capabilities of an environmentally friendly surfactant. This idea formed the basis of one of the most versatile, and effective maintenance products on the market. By changing the dilution ratio Iron-X Snow Soap can be used as an iron-removing Snow Foam with a foam lance, with a mitten or sponge as a Shampoo, a Lubricant for clay and polymer decon products, or even a maintenance Wheel Cleaner. A true Multi-Purpose cleaner…
My personal favorite use of CarPro Iron X Snow Soap is as an excellent solution as a strong prep wash to assist in the removal of old wax, traffic film, grime, dirt, and brake dust/iron contaminants whilst providing an excellent lubricated surface during the wash cycle.
Features:
Ease: Cuts through road grime & traffic film with ease
Safe: pH Neutral
Safe: High Lubricity
Quality: Utilizes only the highest quality cleaning agents & emulsifiers
Safe: Cleanses the bodywork gently with rich foam
Versatile: Use on paint, glass, wheels, headlights, plastic trim, & clear bras
Excellent on wheels (Apply gel directly to wheel and agitate the surface)
Dilutions:
1-3 ounces in your foam cannon for simple snow foaming
Up to 1:8 - Light to Medium iron remover
Do not dilute if you desire a top strength prep solution
Directions as Snow Foam:
Rinse vehicle well
Add Iron X Snow Soap to Foam Cannon
Set your foam cannon to provide the foam concentration you prefer
Snow foam your car as normal and allow to dwell
Wash gently but thoroughly with wash mitt
Rinse thoroughly
Directions as Hand Wash:
Rinse vehicle well
Apply 1 squirt of Iron X Snow Soap directly to wash mitt and wash a panel
Move to next panel(s) and repeat (rinse mitt and apply more product as needed based on level of dirt in mitt)
Allow IX Snow Soap to react but rinse off before it is able to dry on surface
Notes:
IronX Snow Soap will affect oil base waxes by approximately 50%
Avoid use on fabrics.
Precautions:
Do not allow to dry on surface in sun.
Avoid use on hot surfaces or in direct sun.
Wash your hands well after use
May be irritating to eye & skin. We recommend the use of skin and eye protection for total peace of mind.
Keep away from children
I doubt the Sonax Wheel Cleaner will make much of a difference... I'd give TW Chrome Polish & Rust Remover a shot at those wheels. There's not much to to lose.
Sent from my iPhone
I think a Magic Eraser lubed with some diluted APC would work.
or maybe try #0000 steel wool.
Since that appears to be a painted wheel, I'm not sure that would be a good idea. Wouldn't even 0000 steel wool tear up the clear coat and/or the paint underneath?
First take the wheels off the car and lay them flat so when you are working on them everything does not run to the bottom.
I don't like Sonax or Iron-X because they don't clean that well on un coated wheels. Try Dodo Juice Ferrous Dueller Iron Remover as it is the strongest I have found.
Dodo Juice Ferrous Dueller Iron Remover, paint decontamination
I put a crap towel under the rim and spray the wheels down and scrub them as soon and you are done spraying them.
Next I use that towel under them rim and a few other old ones and lay them on top of the problem areas and give them an extra squirt or two
This helps the cleaner stay where you need it to work and not run away.
You have the right process just keep doing the same process over and over and everything will come off eventually.
When they are clean just polish them and seal them with Gyeon Rim.
I will order some then! I saw somebody on YouTube using a plastic thin card to get these embedded bits off but that would scratch big time. Thank you!
I had a similar issue with an old honda accord, the iron actually baked into the wheel had some successfull with steam cleaner and meguiars wheel brightener on the strongest dilution. Not saying to go out and buy brightener but maybe some steam would help amplify the product also since shes are so heavily etched it mightve gone through the clear and into the wheel thus when removing it it will look dull and brownish.
I picked up a bottle the TW chrome polish/rust remover that Eldo recommended to try out. This stuff is pretty good at removing the stains that your typical wheel cleaner won't remove.
I usually use Optimum Poli-Seal to clean them up but I think this works just as well, maybe a little better. I think it may have some abrasives in it but I'm not positive. If there are any, they are very mild.
Nowhere near as bad as what you're dealing with but here are some pics.
Then for the fun of it I decided to see what it would do to the area of the barrel just between the spokes.
After two applications
Then after about 5 apps.
Definitely not just a wipe on/wipe off, it takes some working it with some pressure.
For the light staining in the first few pics, it only took one go at it.
