The only place where its useful is a prewax cleaner for when you want to put on a fresh coat w/o doing any correction work. Dont need it for anything else. You dont use it before or after polishing.
I Don't ! Meg's has several other better choices for this removal process. After you was the car start with a good clay treatment and then follow the processes outlined in other post on this Forum to move from cleaning to polishing to sealent and wax.
Yeah, colorX is a filler wax. Avoid it. Stick with SwirlX, Ultimate Compound and any of the other products that Meguiar's makes other than ColorX.
Really?
I think it is can be useful for other things besides a pre wax cleaner. It can remove heavy oxidation by hand and machine.
ColorX is targeted as a consumer product for removing light swirls and scratches and can remove moderate to heavy oxidation. M66 and D151 are not really a better choice, but more aggressive and can be bought in a larger size.
Seriously?
You cannot compare SwirlX and Ultimate Compound to ColorX. You are comparing apples to oranges.
You are incorrect by stating it is merely a filler wax. It can do much more than that.
I can't think of a better consumer AIO ...
ColorX works well in a simple wax & wax regimen.....Your Daily Driver.
Gonna try this regimen out on some of my friend's cars.
What top coat sealers work best: non-cleaning?
Colorx cannot remove moderate or heavy oxidation. It is a light cleaner wax product. Now it might remove light oxidation on soft single stage paint but then again what light polish wouldnt. It can also remove very light swirling but it will also fill in light swirls also with its wax. You have to remember, waxes are naturally fillers.
I stand by what I said. It's a filler wax. I do NOT use fillers of any sort as I'd rather fix problems than cover them up. That's not to bash those who don't mind hiding problems. Shoot, I know how long it takes to actually correct clearcoat issues, so if you're the average consumer who doesn't want to hire a detailer to fix their paint or invest in the products so they can do it themselves, then by all means, buy a filler wax and go to town.
As a professional though, I won't use something like colorX on my customers cars. Just my personal decision as, like I said, I like to fix problems, not cover them up. To each his own though.![]()
Have you ever used the product on moderate to heavy oxidation? I have been using it as long as it has been on the market. I have probably used it to remove moderate to heavy oxidation over a hundred times.
By the way, Mike Phillips has stated a number of times it is a strong cleaner wax, not a light one.
Here is a good example of what it can do:
1986 Ford Bronco II - Extreme Makeover
I didn't say it doesn't fix problems at all, but it IS a filler wax as is proven by the chemical stripping portions of the thread you linked. After chemically stripping the ColorX portion of the hood he did in that post, MOST of the swirls came right back. Anyone with decent vision can see that.Actually, the fact that you can see the swirls proves that ColorX is not a filler wax.oke:
ColorX is designed to be an all-in-one cleaner wax. It does the job it was created to do, and it does it well at a good price. As I observed above, I can't think of a better AIO offered at the consumer level. Perhaps DG 501, but DG 501 is hard to find.
ColorX does contain mild diminishing abrasives. When used with a DA and polishing pad, it can remove light swirls and scratches, as well as oxidation. I know this from direct experience. In terms of abrasive power, it is comparable to M06. ColorX is also recommended for the removal of micromarring that has been left behind by polishes like M80. Of course, it is not my product of choice for scratch removal. It's best to use products that have been designed precisely for that purpose, as all agree, including the folks at Meguiar's. But if one is looking for a pre-wax paint cleaner that also provides a layer of protection, then ColorX is hard to beat. :xyxthumbs:
You see MORE swirls after it was chemically stripped than you did BEFORE he chemically stripped it, so therefore, it IS a filler wax. Like I said, if it does what you want it to do, then by all means, don't let my feelings stop you from using it, but that doesn't stop it from being what it is, a filler wax. There is a place for filler waxes and glazes in the detailing world, just not in my line-up of detailing products. I choose to fix, not fill, hide and coverup. Some people don't want to dedicate the time it takes to actually correcting paint, and that's totally okay, not everyone has a day or two or more to dedicate to sitting in a chair and compounding out scratches and swirls till their gone, but I do, since I'm not making money any other way and I'd rather be great at fixing than amazing at covering up. Doesn't mean I can't throw a quick wash and wax on a car and be done with it, but it's eating me up inside when I see the swirls covering a car I just washed and waxed...I'm sure I"m not alone in that feeling though.
