When will AG have Carpro Gliss?
Jeremy1976
Anyone know? I know you can get it on Amazon, EBay, and directly from Carpro. I need other stuff though and want to order all from the same place.
Thanks
Sent from my SM-N950U using Tapatalk
Don't know, but when you get it, be sure to follow the directions carefully. As example, if your now using Reload, you must strip it before applying Gliss. Any other waxes, sealants, quick detailers and waterless/rinseless/, bucket wash soaps would probably be the same.
I'll just stick with UK and maintain it with Reload then. Thanks.
Don't let the prep work scare you off from trying Gliss over UK. It's not as bad as it sounds. Feel free to PM me if you need tips with Gliss as I have been playing around with it here and there.
I'm not concerned with the prep. Just not sure if it pays to add a top layer when I am going to be using Reload often. I will see. I can always apply Gliss down the road.
Hopefully AG will reply to your original question. I would like to buy some too.
Would anyone with experience recommend these new top coats as something someone could just use as a stand-alone?
I know it’s listed as a great standalone under the features, just curious if anyone has tried it.
this being much more slick than the base base coat offerings, this could be something I’d be interested in as using vs buying two layers AND topping off the coating with reload.
