Where to buy Duragloss 501 locally?
LuxuryMobile
Picked up a last minute job tomorrow and would like to use DG501.
Obviously don't have time to order it, any ideas where I could buy locally? Boats store, auto parts store, etc.
+1 on CARQUEST. You can go on the website and enter your zipcode and should be able to tell if they have it at your store before you make the drive. I think you have to add it to your cart first, then if it says "available today" in the cart (you have to go to checkout to show availability), the store should have it in stock (at least in my experience). If you have multiple stores in your area, you can try first one then when you go to checkout if it says "available next business day" or something to that effect, just below that it should have a link for "check other stores". click on that and it will show the availability at other stores in your area.
DG's website has locations on their site, check it out.
Thanks for all the responses. Called Carquest and they had some in stock. Perfect.
Have a flats boat to do tomorrow, should clean up nicely.
