gofast908z
- Feb 5, 2009
- 746
The store I normally get it from doesn't carry it any longer. Does anyone know what kind of local stores would carry the deionized water?
-As far as quality is concerned...distilled water is better than deionized water.
De-ionized = distilled. Distillation is a process through heating the water that allows it to be separated from the ionic content that naturally occurs in water (minerals).
I can see the benefits for distiller water ...
I rinse soap off with regular tap water and then do a final rinse with distilled water to reduce changes of water spots.
What is deionized water used for? Is it better than distilled?
where does ro water fit in this equation ? is it any more filtered or removed of impurities than distilled?... if ro is as good or better than distilled I shouldnt be getting jugs for Wally world ?
After using tap water to rinse off the soap, how do you apply the distilled water? Do just pour from the jug, or spray it on? I’ve never thought about doing this as a second rinse. I like the idea.
Thanks,
Greg
