I don't do anything by hand but buffing... this starter kit maybe what your looking for.
Treat yourself to a fresh stock of applicator pads!
This kit contains an assortment of our most popular pads. You'll be sure to have the right applicator pad for any detailing job.
2 Cobra Tire Dressing Pads
The
Cobra Tire Dressing Applicator, good also for molded plastic, is perfect for applying dressings or protectants to tires. A finger groove encircles the circumference of a two-inch-thick pad of high quality poly foam—the best material for applying tire dressings. The closed-cell applicator disperses any kind of tire dressing evenly and consistently for a sensational result, but keeps your hands away from the mess.
2 Wolfgang Finger Pockets
Wolfgang Finger Pockets are the easiest way to clean or polish tight places. These foam pockets fit over three or four fingers so you can maneuver in small spots. The foam has light cutting power so its perfect for polishing metal components. Finger Pockets allow you to reach between the slats in your vehicle’s grill or between spokes. The foam is more absorbent than a towel so it’s great for product application.
6 Pinnacle Foam Wax Applicators
These universal applicators are made of quality closed cell soft poly-foam. They are pliable, strong, and efficient. Use again and again, for any applicator need, then simply toss in the washing machine and they are good as new.
8 Cobra Terry Cloth Pads
The terry pad is perfect for applying pre-was cleaners, polishes, and all dressings. Excellent for leather cleaners and conditioners. The 4" x 5" applicator pad fits nicely in your hand, and the thickness (1”) seems just right. Quality terry fabric is wrapped snuggly around a dense closed cell, poly-foam pad. Easily machine wash and dry.
4 Cobra Microfiber Applicator Pads (COLOR MAY VARY)
The outer surface of the
Cobra Microfiber Applicator Pad has all the qualities you’ve come to expect from the finest in microfiber technology. The gentle, yet strong fabric is wrapped snuggly around a plush, absorbent sponge. This innovative combination of materials causes wax, polish, dressings, and sealants to spread more evenly, resulting in maximum coverage while using less emulsion.
This kit contains 22 applicators! You won’t find a better value anywhere!
Kit includes:
8 Cobra Terry Cloth Applicator Pads
A total retail value of $52.25. A savings of $22.26!
