which is easier for a newb, opt hyper polish/compound or megs
05rsx911
Im getting rdy to do my first detail with a flex 3401 with LC hydro Tech pads.
which would be easier for me to use while producing great results. Opt hyper polish and compound, or megs 105/205. I already own hyper polish and have yet to use j/w which would be produce bettter results
the only gripe about hyperpolish is that the sprayer isn't consistent. Not sure if it's right off the bat or after product dries and partially clogs the sprayer itself.
Other than that I think you should get great results from what you've got.
If it's really not working for you then you might be able to get 8oz of 105 OTC at pepboys, AZ, or even wally world apparently...
M105 sometimes can be tricky with flash passes. It takes awhile to get use to dealing with it and adapting to it. It changes alot depending on the weather.
With that being said, I still think you should got the 105/205 route. The correction that can be done is amazing with it.
Do u think I would need to do the hyper compound first or just the polish and an orange hydro pad will give good results
do a test spot with the hyperpolish on tangerine first
if no good then hyper compound on cyan
