the_invisible
- Sep 20, 2009
- 72
Which is more aggressive if used with the PCXP and orange pad on non-ceramic clear coat paint? I have both, but I have never, nor could I, compare the two side by side to determine which is more aggressive.
I need to order some mid-high aggressive polish. I think Ultimate Compound used with the DA gives acceptable correction power. Acceptable, but nothing dramatic. I want to use something more expensive and can be used with the rotary. I don't like the way UC behaves on some paint. UC seems to behave very differently on different types of paints.
I understand that one is SMAT and the other is Diminishing Abrasive, but subjectively speaking, which is more aggressive generally speaking from YOUR experience? UC or SIP/PO203S?
