Which is the most ideal drying towel?
William D.
Hi all,
I need to upgrade all of my microfiber towels, as the ones I have don't seem to pick up water like they should anymore (and are fairly soiled.) Which works the best for drying off a car? I don't want a massive 24x36 towel, as they are just a pain to work with, from my experiences.
I'm looking at getting some of these:
Mango Breeze Microfiber Towel, mango buffing towel, microfiber towel, detailing towel
Good idea?
Any other input is appreciated, I don't know how long the "BOGO" sale will last, however.
The Guzzlers by far are the best drying towel AG sells. The Mangos are not going to make a good drying towel.
A waffle weave drying towel are generally better for drying than a plushy towel. The Guzzler is a great drying towel.
I used a water sprite for many years, which is probably the best synthetic chamois. Some think the WW MF causes less potential for swirls than the water sprite. Some think the MF will remove wax while the water sprite does not. I am not convinced one way or another having used both. In some ways, I like the water sprite because I can rinse and wring out the chamois often as I use a QD when drying easier than the WW MF towel. I can use the same towel for multiple cars without buying more large MR towels.
That being said, the Guzzler is what I use regularly.
I would not use a real chamois.
Green Guzzler indeed ... it comes in small size too.
I just realized I hadn't clicked "Add to Cart" when I placed my order. CRAP!
Is there any way to contact someone and add it? I don't want to pay $24 for two towels, when I could have combined them.
CRAP!!!
CRAP!!!
Umm click on "Contact Us" at the top of the home page. Your package wont ship out until tomorrow, there is plenty of time to change it.
I just dropped them a line, I hope they get it in time.
I'll try a waffle weave again, but I bought one before (not here) and it was HORRIBLE. In fact, I only used it once, then used it as a grease rag, I was so dis-satisfied with it. Hopefully this one will be better, although, I thought waffle-weaves would likely scratch the surface, whereas mega-plush ones wouldn't and would also soak up the water..?
Guzzler.
The bigger the better. And wash them by themselves, not with ANY other towels.
If you're talking about the walmart ones or the ones from a parts store then they don't even compare to the Guzzlers.
IME the HD Guzzler is the best drying towel I have ever tried and its the perfect size too!
The 16 x 24 Guzzler is the best I've found and now I have a dozen of them..:props:
I used a Water Sprite for years and loved it. Got some other brands on sale, and they weren't nearly as good, even when new. Got a couple of blue waffle weave (turd-le Wax) on sale, and liked them the first couple times, but not so much any more, they leave water spot trails unless I use a blade first. I probably washed them wrong, so it' may be my own fault. I also got a yellow plush MF drying towel was awful from the first time. I'm using it as a QD wipe off towel now. That Wal - Mart stuff isn't worth the money, the next time, I'll go with stuff from AG, and use the cheapies for door jambs and wheels. YOU GETS WHAT YOU PAYS FOR!
Ok, good. It was a Armor-All brand one, I believe. Horrible POS.
I know were talking towels here but for the sake of it, does anyone still use the absorber?
