Which Leather Master product for Alcantara seats?
bmwgeek
I looked through the selection Autogeek has and doesn't seem like any mention alcantara seats. Doesn't look like the mousse works either. They have everything except the Leather Master Foam Cleaner.
Go here: Alcantara
for some excellent info from the people that personify and are Alcantara, per se.
Also (From TOGWT's blog):
"Ultra suede (Escaine, Alacantra):
Is a 100% Polyester man-made suede substitute, which should be cleaned by brushing the nap with a soft nylon upholstery brush, remove pilling with a single-sided razor blade and then applying a cleaning solution (Water /Woolite® or Dreft® with a ratio of 5:1 or stronger) on to an applicator pad and apply to one area at a time (do not over-wet the fabric) and do not use steam. Localized stains can be treated with a citrus-based cleaner, ensure surface is dry before use by leaving window cracked/open. For heavy stain removal- 1:1 Folex Instant Carpet Spot Remover / Distilled water- Folex Instant Carpet Spot Remover removes spots and stains
Identifying characteristics- very soft to the touch will scratch or scuff very easily; water drops will darken the leather but it returns to its original colour after drying.
Maintenance- Use a soft brush lightly to remove dust and raise the fabrics nap, once your seats / steering wheel / interior is clean, you should use a conditioning/protection product (303™ High Tech Fabric Guard, which includes UVR protection"
Hope this helps!
