Which one ? Meguiar's MT300 or GG 6" DA?
Marc Hufnagel
Member
Looking to get one or the other - Meguia's MT300 or GG 6"?
Just my own personal cars, so I'm really stuck on which one to go for?
It really comes down to form factor.
I personally prefer long body tools for my full size polishers, so I started with the MT300. Paired with thinpros, you really don’t need a long throw. It’s a beast and works really well.
The gg6 is no slouch either and with boss pads or thinpros should do well also. It’s a small body polished which a lot of people prefer, along the lines of a porter cable.
Can’t really go wrong either way, IMO.
The GG6 has all the power/torque you'll need even if you don't use thin pads---with a 5" backing plate and 5.5" pads there isn't much it can't do. Add the Heavy Duty 3" backing plate and 3 inch pads and you're good to go for even the small tight areas on the car. And to top it all off the GG6 has a lifetime warranty. Since you're only taking care of your own cars you'll probably only use it a couple of times each year so imagine if it has a problem 3 or 4 years down the road---do you want to spend a minimum of $80 to have it repaired or a phone call to Griots for a return authorization where they will most likely just send you a new polisher????
Here's a post by Mike Phillips that list everything you need to get started in machine polishing: Here's what you need to get into machine polishing - Recommendations for a beginner by Mike Phillips
Thank you for your thoughts on this. It sounds like the GG is going to be the best choice. Appreciate it!
The Meguiars MT300 is no doubt the better polisher, as long as it doesn’t break down.
Mine went through a weird phase where it didn’t want to turn on, but after some choice words it stopped doing that (I never took it apart because I’m lazy, don’t judge me.)
I do enjoy using it, but sometimes I wish I had gotten the gg6, just because I think I’d prefer the porter cable body style more. I often find myself holding the mt300 up in the middle just because of my own personal tendencies to tilt the machine.
I also don’t enjoy attaching a 3” plate to it (it works fine, the size of the body just makes it feel weird.) it’s one of those situations where if I ever get a more robust machine, I don’t see this one ever getting used again, because I’d rather have a smaller machine (pc7424, gg6) to use for edge work.
Glad to see people like the mt300 though, i don’t see it talked about often. I’m assuming because of the price point. It’s a real nice tool though, and it’s done whatever I’ve wanted it to.
Can not speak about the MT300, but I have a GG6 and love it. So far, it's handled everything I've thrown at it. Plenty of power, a lifetime warranty, and it's roughly 100.00 less than the MT300...what more could you ask for?
I've had a GG6 since 2007. It still works great, just looks a little rough. This little machine is a workhorse!
Bill
I really like the smaller body style of the PC/Duetto.
If I get a chance to get a Megs g110v2, I might pick one up. I doubt It's going to be a radical departure from the PC.
I’ve considered getting a duetto as well, for that very reason.
Maybe I’ll keep an eye out for a used PC or megs machine, that’s not a bad idea
You can sometimes find an old 7424 fairly cheap on CL. I found one almost new on the bay for $40.00 + 10 shipping. Not bad for a tool that's almost bullet proof.
And even though It's probably the weakest random orbital ever created (the 7424), it's still the one I use most. With today's abrasives and pads, you can really get a lot of work done with them, with great comfort, because It's even smaller and lighter than the 7424xp.
If you go the route of the Duetto, you will experience a jump in performance and user experience.
I've had my GG6 for 7 years and still runs smooth and powerful, I had the mt300 for about a week and got rid of it, to much vibration and not enough torque
