Hello All,
This is my first post and I have a questioned (which has probably been asked)... which should go on first a sealant or the wax.....? I never used a sealant before,
I had always used a wax and my thinking always was that after I waxed my car I would throw a towel across the front of my hood and watch slide across the roof and off the back of my car, which kind of told me the car had a very smooth surface and that if you were to lean on the car you would slide off it, not to mention all the water would bead up as well.
So now I want to have the same effect....but I heard that a carnauba wax gives a nice warm and deep finish but a sealant kind of gives a bright finish and which kind of finish do you end up with if you use both products (warm deep or bright) if both products are suppose to protect your paint, and depending which I apply first what am I doing ....?
If I apply the sealant first I guess I'm protecting the paint first and then when applying the wax is the wax protecting the sealant that's protecting the paint?, or if I do the reverse is the sealant sealing the wax that over the paint...?
How about this question....when do you know when again to apply the sealant or the wax....?
At least when I was just using wax I knew when the water didn't bead up or the car didn't have that slippery feeling... whewww
