Which pad to use with Flex 3401
petiebear
I just purchased a Flex 3401 and LC pads from you. I have a black 07 Corvette
with light to medium swirl marks. Which pad should I use ? I am using Menzerna
Intensive Polish.
Thanks !
Try a white first. If that doesn't do much bump it up to the orange. Both those pads with that polish need to be followed up w/a finishing polish and finishing pad.
If you only have that pad and polish, use the white pad with the IP. You should be able to finish down good enough on the harder clear.
Intensive Polish.
Thanks !
IMO trying to do a one step process on a corvette isn't going to finish down with just using Menz ip.If the swirls are medium like you say do a test spot and see how it looks.But as Loudog mentioned you really need to follow the IP up.
The white pad should do the trick but does need to be followed up, Don't ask me how I know this, I just do.:dblthumb2:
