Hi Mike,
I've seen you use orange and white pads with AIO Blackfire, and I know I need to test each before doing the car, but I wanted a pad recommendation.
Also, why do some pads have a hole in the center?
I have a 2016 Ford Mustang, Deep Impact Blue (see photo) overall the car is clean with some light swirls that I'm looking to remove and detail the whole car.
Which pad do you recommend, I'm using a TORQX random orbital polisher with 6 inch backing plate.
Also the car is the CA edition and it has piano black accents, just as the mirrors, spoiler, and decklid panel which are super soft, basically swirl by breathing on them
Nice looking car....
We had ONE CG Torx polisher here at Autogeek years ago. I found it to be one of the weakest free spinning random orbital polishers on the market. A few months ago, Meghan asked me to put together a collection of tools to send to Dr. Beasley's in Chicago for Jim Lafeber's Detailing Clinics. I think I sent him basically one of every tool in my tool collection for my classes including the Torx 10FX - I never used it except to let people compare it to the power of the Porter Cable the the Griot's polishers.
So the key thing you need to do is use pads that will ROTATE well with this tool and my guess is you'll need to get rid of the 6" backing plate and get a 5" backing plate. You can stick with the 6" backing plate but now you're going to start investing your PAD MONEY into 6.5" pads and build up a collection or INVESTMENT into large pads that in my experience - are simply not going to rotate well on this tool.
Gosh I spend a LOT of time talking about pads and pad rotation on this forum. :dunno:
When you see me using pads with hole in them, that's because I'm using the BEAST! It's a GEAR-DRIVEN orbital polisher. It does not understand what pad stalling means? This is why I use it. I don't like to waste my time in the garage. I want to get in and get out. By this I mean, I want to PLOW through the machine buffing steps as FAST as HUMANLY possible while keeping my results PRO QUALITY. Thus I use the BEAST and not free spinning random orbital polishers.
Here's your choices for THIN 6.5" pads that will fit your 6" backing plate. I don't have an article on this collection of brands of pads because since they were introduced - I never recommend them - instead I strongly recommend people buy the 5" backing plate and I DO have an article for all the THIN 5.5" pads that I'll share below.
For these ThinPro pads, (ThinPro is one word), you'll ant orange, white and black
Lake Country ThinPro Foam Pad System 6.5 Inch
For these Meguiar's 6" foam discs - you'll probably only need the yellow and black. The maroon is very coarse and sharp (its' a cutting pad)
Meguiars 6 Inch DA Foam Discs
If you want to go with Griot's BOSS pads, they will fit any 6" backing plate too. I'd get the Orange, yellow and black. The white pads are very coarse and sharp like the Meguiar's maroon pads - in fact, even sharper.
Griots Garage 6 inch BOSS Foam and Microfiber Pads
If you want to switch your Torx FX over to a 5" backing plate, I share the links to these and the 5.5" pad options PLUS TONS OF INFO TO GET YOU GOING IN MACHINE POLISHING.
I would highly recommend reading this write-up, not scanning it.
Here's what you need to get into machine polishing - Recommendations for a beginner by Mike Phillips
Then watch the video in post number #2 - it will show you EXACTLY what to do with your Torx polisher.
Also - you're MUST either mark your backing plate or mark your pads to make it easy for your eyeballs to see pad rotation. If you can do both - do it.
Video: Mark your backing plate to make it easy to see pad rotation
See this article too...
How to Monitor Pad Rotation? Mark Your Buffing Pads
Here's something I say that I've had other Detailing Gurus actually argue against me on. This of course in in the context of a FREE SPINNING RANDOM ORBITAL POLISHER - like yours, like most of the polishers on the market except the FLEX BEAST, Supa BEAST, CBEAST, RUPES Mille and Makita PO5000C
If the a pad isn't rotating - you are not doing anything
and by this I mean, when you turn the polisher on and are buffing out a panel, the pad must both rotate and oscillate. If it's not doing both all it's doing is jiggling or vibrating against the paint, or even worst, just sitting there doing nothing to the paint and that's the point - you are not doing anything, as in you are NOT removing swirls, scratches, water spots or oxidation. You are wasting your time.
The pad must rotate in order to remove defects. Period. Thus mark your backing plate and pads to make it easy to see with your EYEBALLS if the pad is rotating or just stalling out as everyone says.
Hope this helps...
