Which Polish
FourEyes45
Im using WGDGPS 3.0 Which polish should I use??
Menzerna PO 106A or Menzerna final Polish...I heard a lot about the 106A...Will be using it on a 2005 HDDM Chevy. truck and a 2008 Rubicon Jeep...Thanks for any info.Feed back please
Which Wolfgang polish, Total Swirl Remover ?? If so, look for Menzerna 085rd which is one of the best finishing polishes.
Both the PO 106A or Menzerna final Polish PO85U are pretty light polishes, on the graph on this page they are listed as able to remove #2500 grit sanding marks which in and of themselves are pretty light.
Menzerna Chart
When you get to this gentle of a polish what's just as important is your choice of pad, you're choice of machine and your technique.
I should have added more Info....I have and use Wolfgang products.
Total Swirl Remover 3.0, paintwork Polish Ehancher, Finishing Glaze 3.0, Deep Gloss Paint Sealant 3.0 and Pinnacle Sig. Series II Wax..
Would Menzerna 085rd.or 106FA help or do I need to use a polish at all???As you can tell Im a noob....
Thanks Gang...And I hope all had A Happy and Merry Christmas...
Walt
WG Finishing Glaze is made by Menzerna and is a tweak on their 106FA....so I'd use that to remove fine swirls and be my finishing polish. I use it alot and find it to perform the same as 106FA. I also use WG TSR and PPE. The WG TSR is a good swirl remover (kind of like Menzerna's SIP), and WG PPE is a cleaner with very mild fillers. After polishing you could use it to clean things up a bit, but it's probably overkill. I would not buy more polishes. You have 3 excellent ones.
