Which polisher to get next?
Rf560
Hi everybody. I have a Groit's 6 inch DA polisher and a air powered 3 inch rotary. I want to upgrade to all Rupes. I am debating on which to get first, the 75e Mini Duetto to replace my 3 inch or the 21 bigfoot for faster correcting/polishing. Can't afford both at the same time. Should I get the 21 first and just put a 3 inch backing plate on the Groit's for now? ......or get the Mini first? Thanks for your opinions.
Sent using AG Online
Id go with the rupes 21 first, and do the 3inch backing plate on the other machine. If its in your budget I might recommend grabbing the 5inch backing plate for the 21 as well. It makes the machine able to go into smaller areas.
or you can get the flex with the lc backing plate system and be able to use 4"-6.5" pads all in one machine...
Thanks everyone. I appreciate the input. Rupes 21 Bigfoot it is.
