Which waterless wash?
Supergus1
So it's that time of the year up here in New England. Too cold to wash, too much road grime for the touch free car wash to clean. What are your thoughts on waterless washes? Which brand would you tend to be faithful to? Also, is there a temp that may be too low for waterless washes?
if the ambient in the area where the car resides is freezing, the waterless will freeze on the panel too.
do you have access to a garage? even if the garage isn't insulated, it can help keep temps high enough to prevent freezing.
if i didn't have a garage and/or my temperature controlled water source, and it was THAT cold, i'd probably just use the sprayers at the DIY wash to get the main stuff off and keep the undercarriage as clean as possible either before a wash or until i could wash. i would hate spending money on such a thing though, i'm too frugal haha.
IMO:
•If a waterless-wash product is water-based/water dilutable...it'll have a freezing-point.
-Probably a little lower than 32°F.
-Don't forget about the wind-chill factor: It can rapidly
drive temperatures downward when washing outdoors.
•Meguiar's D114 is my favorite "waterless-wash" product.
Unfortunately I don't have a garage, and like you, don't like spending money, especially for lack luster results. At the DIY wash it costs me $6 just to rinse, and if I use soap first, I'm up to $10-12. And that doesn't remove the road film. I've learned to take advantage of every day above freezing so i figured a waterless product would do the trick.
Bob, thanks for the input. I had forgotten about Meg's. I usually think DP, Pinnacle, etc for waterless stuff.
+1 on d114. That stuff is Legit! If you crave something with some protection built in, look into d115.
I think Pinnacle Waterless is the best deal for what you get. Pinnacle Waterless dilution rates are 1:32 ratio which is 1 oz of solution to a 32oz bottle. One gallon of concentrate will make 128 32 oz bottles or 32 gallons of waterless wash. Ultima Waterless Wash will make more gallons but the Pinnacle in my opinion leaves a better shine due the Carnauba Wax.
Mega dittos.
I've been using Ecosmart by Chemical guys. It's good for the summer, and "quick wash" of the daily road grime (in between weekly washes). During the winter, when I can't do the weekly wash, I'm switching to a rinseless wash.
I bought a lot of Eco Touch when it was on clearance. It is amazing. It's protection really does last a while, at least a week since that's the longest I've gone between it and a regular wash. It could've easily lasted longer. The spray bottle is also fantastic and uses very little product with a great sprayer. Works well on glass and makes water sheet off well too.
Correct me if I'm wrong, but isn't D114 a rinsless (@1:128) that can be used as a waterless (@1:4).
I've tried to buy into the idea of using a rinsless as a waterless, but the dillution ratios make it cost prohibitive.
@1:4?
Might you be thinking about Meguiar's D115?
I've used 2 different waterless washes to date with great success. My first was ECO TOUCH, won a contest for it here on AG (thanks Nick) and it was very easy to use! Its all environmentally friendly contents and left a VERY nice finish!! The next and current one is Griot's Garages version of it. This product is equally easy to use and also leaves a great finish and FWIW both products smell great:dblthumb2:
IMO the key when using ANY waterless wash is plush, MF towel, preferably edgeless ones. Depending upon the size of the car, you should have atleast 6 of them and maybe one special one for buffing, atleast a dry one for it. Just follow the vids posted here for using the waterless wash and you'll be good to go.
My preference is the OPT No Rinse/Shine. The verdict on Meg's. D-114 is still out. You will see diff. opinions. My choice is to make sure to get the road salt (chunks) off as soon as possible at coin op. with spray. When the temp. rises then you can work on the rest with what ever product you decide on. This area has been discussed numerous times in past threads, etc.
I actually prefer rinseless over waterless when the car is DIRTY! Pre-washing with rinseless makes it a breeze, then dunking your wash media and wringing it out, again, a lot easier IMO.
That said, you can do the same with waterless but like said before, hitting the quarter carwash before hand is a smart move, plus you'll get more of the stuff off of the car and end up using less towels, that's always a good thing! The same technique mentioned here can also be used when doing a rinseless too:thumbup:
Sent from my SPH-M930 using Tapatalk 2
Klasse:
"IMO the key when using ANY waterless wash is plush, MF towel, preferably edgeless ones"
I for one would like to know which edgeless MF towels do you use?
I'm sorry, but ONR sucks as a waterless wash. It's great as a rinseless wash though.
I've also used it at 1:256 :dblthumb2:
Is that waterless, Bob? D114 is a rinseless at 1:128. You're actually diluting it even more with double the amount of water to use as a waterless wash?? Hard to believe...
I would think a plush MF towel would when used with a waterless wash, would be kind of heavy.
