Which wax over Wolfgang 3.0 sealant
tommyjitsu
I plan on buying the wolfgang 3.0 sealant and was wondering if you would suggest layering it with the Fuzion or the Souveran wax? Better to stay with same manufacturer or is Souveran the better choice? I have been reading but still a little unsure.
If your trying to stay with the 3.0 DGPS look then I would use fuzion, P21S 100%, Dodo diamond white/light fantastic. Soveran will change the look of the 3.0 DGPS. It will give it a warm wet glow, instead of a crisp glossy look.IMO
If it's black, no question Souveran. Any other color I would go with P21S 100 or Fuzion.
I would top it with another layer of DGS and leave it. It looks good on all colors from what I have seen and what others have posted. I like the look it has on it's own.
What look will Fuzion add to DGPS, vs using DGPS alone or Fuzion alone?
Looks is subjective, but I use a nuba over a sealant mainly to protect my paint from bird bombs. Nubas protect better than sealants against bird bombs.
Like some others have already said -depends on the color.
Black/Red -Souveran all the way. Will definitely warm up the finish
Metallic -might I suggest SSII. Awesome 'nauba for metallics.
If you like the looks of DGPS, Fuzion would only add to that look
I used P21S 100% over a metallic silver, DGPS looked awesome before, now it looks awesome with greater depth!
I have found the DoDo Juice Wax to be top quality.I put a coat of Super Natural over the Souveran Paste. For black the the Purple Haze would be good,I'm sure!
If you must put something over it. Fuzion would be the way to go but I would just add another coat of DGPS...:D
So adding any OTHER brand of Wax over 3.0 is actually harmful ?
What if I don't OR can't buy that real expensive Wax that you guys recommend ?
Just do without... and simply apply another layer of 3.0 ?
:buffing:
:buffing:
No, applying any nuba over 3.0 is not harmful. Nothing wrong with 2 coats of 3.0.
