White Camry Problems...
pcw25
My Toyota Camry (DD) is in pretty good shape for being an 07 with 130,000 miles. The car's paint has NEVER gone flat (water always beads off it). I seems that with the super white I see gray areas (spotty) if you look closely. I also see a bunch of random yellow/black dots everywhere. To the normal person, it would look great. It has light swirls, and I've never done a paint correction on it, ever. I apologize for no pictures, we had a freak snowstorm where there was LITERALLY an inch on the ground in less than 5 minutes. Suggestions?
What you are seeing is quite likely tar and built up grime. There is also very likely some overspray from road painting etc and some rail dust. If you don't feel like buffing I would:
Wash (Two Bucket)
IronX
TarX
Clay
Sealant & Wax
Ideally it is probably in need of a full correction if you do have the equipment.
Yup sounds like you have some tar spots and rail dust. Very common to see this on white, it sticks out like a soar thumb.
Like everyone else says do a good decontamination or clay and polish it. A simple cleaner polish should work very well and will help with some of the light swirls.
