Hello:
Couple questions on touching up paint chips on white pearl paint. I am using the OEM touch-up bottle with a base coat and a pearl coat.
What color is the primer underneath generally for white paint? I am worried dark primer will show through the touch-up.
Is primer necessary on rock chip areas exposed to bare metal after rust is removed?
I was going to use Wurth self-etch primer or Dupli-Color sandable primer. Is self-etch primer safe for touching up paint chips? I have researched what primer the paintscratch.com primer pen uses, and it is actually Dupli-Color filler primer based on the MSDS sheet.
Wurth Self Etch Primer, self etching primer, metal primer paint, primer spray paint
Dupli-Color DAP1689 - Sandable Primer | O'Reilly Auto Parts
1 oz. Primer Bottle | PaintScratch.com
Have any of you had decent results using the OEM touch up paint? I realize there may be a small blob, but is the color match acceptable?
Thank you
- Will
Thank you
- Will
