Who else vacuums their refrigerator coils? Lol.
Eldorado2k
It’s been several months since I did it for the 1st time and It’s probably due for what should be a twice per year detail. When I did it a few months ago it was the 1st time and it was wickedly caked in dust.
I’ve got a process that involves initial vacuuming with a crevice tool, an extended crevice tool made to reach underneath sofas & appliances, a .5” od rubber tube that’s the real game changer to reach into the tiniest of areas inside the coils, and finally the Master Blaster Sidekick to blow out any remaining dust bunnies into my vacuum on the opposite side of the fridge.
Does anyone else vacuum their refrigerator coils? I can’t be the only 1 who finds this extremely satisfying.
You’re not the only one, I do it too. I wish it was more accessible though, sucks to do that so I do once or twice a year.
My thing is changing filters in our forced air heater. They recommend every 3 months under normal use. There is no way I'm keeping them in there for more than 40 days.
I wish I could on this particular unit....
It's not a column fridge/freezer but a standard *consumer type*
It does have dual compressors (one for fridge/freezer)
Thing ways like 500lbs but the crazy thing is the way it's setup, there coils are not accessible. I'll have to revisit this since you posted this, but by going off memory when the unit was delivered and I went to figure out how to -maintenance it-, no access panel on this thing
There’s gotta be a way…
Did it awhile back. Made the mistake of blowing it all out. Made a mess in the kitchen. Then just vacuumed the mess up. Also guilty of using the leaf blower in the basement to blow the ceiling free of cobwebs.
The back if I recall has zero screws.....WAG would be from the bottom...but this easily 500lb'ish. It managed to put small -caster dent- due to shear weight in our Santos Mahogany flooring which in itself is like 2200 Janka hardness
I specifically recall calling the manuf. saying, hey, best practice to keep coils clean, etc. How do I do it on this. Rep actually pulled up the parts schematic on the phone and id my memory is accurate, she said, you don't, you can't, etc.....
Yup! Usually once per year. When I see the mess, I always say to myself I should do it more often lol.
How about opening the dryer to vacuum lint? It’s insane the amount of lint that isn’t trapped by the screen. After I opened mine for repair, I saw how bad it is and try to clean it once a year. If you haven’t done it, prepare to be amazed at how much lint is in there.
May this needs to be a new thread on the never ending household chore list
I just swept the chimneys, and disassembled the flue on water/boiler and gave it all a good cleaning.
On my planned next weekend of was the same for the dryer ducts.
Then comes spring around the corner and then comes the exterior pressure washer cleaning and the never ending list
I do mine twice a year as well.
My house also has electric heat. (Each room has its own thermostat which is nice. You can turn the heat down in all the rooms you are not using.)
But each baseboards heating element/fins needs to be cleaned every so often during the winter. (During the summer, I plug the openings with foam to seal them.)
I also started doing my dryer like Bruno mentioned. I had to take the dryer apart about 7 years ago to replace the drum belt, and I was shocked at the lint packed inside of it. Those lint traps don't catch everything, believe me.....
And speaking of dryers, I also replace the dryer vent hose every 6 months. For about 20 bucks, it beats the hell out of cleaning them IMO.
Why would you use a blower on cobwebs? Lol.
You’re supposed to use the wands + crevice tool. It doesn’t get much more satisfying than that. Lol
How about appliance cleaning? I run cleaner thru the dishwasher and washing machine about every 3-months.
Having just replaced my fridge 2 months ago because of what the repair guy credited to extreme dust/dirt accumulation on the back i now religiously vaccum my fridge guts. $3000 teaches a hard lesson.
I have been doing my dryer and vent tube for years but never really thought of the fridge.
Like others have mentioned, mine has a sea of coils on the underside but only access to the front couple rows.
Seeing Paul A's post I might have to pull that thing away from the wall and give it another go...
