I'm having both a rotary (Makita 9227CB) and a DA for my car. I'm still doubting what's the best for painted plastic bumpers (and other pieces these days - including front-fenders on my X5 eg). By testing on some panels I've noticed that with the rotary and a relatively small polishing-pad (ex W8204) it's still dangerous and goes pretty fast to burn through the paint on edges/body lines.
Is it better to use a whool-pad (ex W4003) as they tend to generate less heat on the surface (as the fibers are more loose) ? Or is that still risky and better trying to correct defects with the dual-action & cutting/polishing pad ? I know the correct answer is it depends what you want to do and what you need to correct, but let's say I'm trying to remove sanding-marks from 2000 gritt (trying to get rid of some of the orange-peel on my car). Then the order could be:
1) Whool & rotary (with M105 to remove the sanding marks)
2) Foam polishing pad & DA (with M205 to bring it to high gloss)
Not sure if this is the safest/best route that will bring the results ... Any advise appreciated.
Thanks
/GV
Thanks
/GV
