If you really want to make sure it last a long time then remove the spray head from the bottle and pump through some clean water after use. You could then replace it onto the WB spray bottle, just don't pump it till you're ready to actually clean some wheels.
Got some PoorBoys wheel cleaner, great stuff, but the sprayer bit the dust after the first application. A bit surprised the sprayer from the mfg didn't hold up to its own product.
Also got some ARO, equally impressive product. Should I take precautions to protect the sprayer by removing and flushing or will it hold up to its own product?
Thanks
That's simply the best sprayer we can purchase (S+R is some strong stuff) its only chemical resistant not chemical proof. You should take out and spray water from your wash bucket through it a couple times before you put back on bottle than it will last forever.
Easily done. Thanks for the reply, it is really nice to have mfg support here in the forums. Once again I will say that I am thouroughly impressed with the product.:xyxthumbs:
