budman3
- Mar 3, 2006
- 1,744
I’m kind of baffled how aggressive people get with their pad selections. Using an LC green or yellow pad or Edge orange, green or yellow pads is like taking sandpaper to the car, IMO. I see no reason to go this aggressive on pads. I would much rather see someone bump up to a stronger polish verses going to a stronger pad.
Pads are going to be aggressive no matter what. Polishes, on the other hand, usually have diminishing abrasives which brake down over time. This means that the polish or compound starts off aggressive but over time it breaks down into a fine polish, usually leaving the finish without deep micro-marring. That is if you don’t use an aggressive pad…
A coarse pad is going to cut the paint at the same rate whether you are just starting to polish or finishing up. Most likely you are going to be cutting the paint so much that you’ll leave the dreaded micro-marring. So now you’ll have to use another aggressive polish to cut through your micro-marring. BUT, chances are, if you used a less aggressive pad to begin with, you wouldn’t need the second polishing stage which means you will be saving precious clear coat. This may not be the case for everyone, but I find that if I can’t polish out some swirls with an aggressive polish and a polishing pad, that it is safer to live with them verses risking going to strong. Or simply go over the vehicle once again with the same product / pad combo...
Every car and situation is different though, but if you have to use a cutting pad on your vehicles a few times a year, then you may want to work on your washing techniques. This is just some food for thought that I have generated after a steady month of reading on this site.
The old verbiage of “use the least aggressive polish first” should be something like “use the least aggressive polish and pad first, if that doesn’t work, use a stronger polish, if that doesn’t work, do another pass with the same polish, if that doesn’t work, bump back on the polish and go to a stronger pad, and so on.” That quote is from me
Sorry this has gotten so long, maybe it is just me but I feel that using a stronger polish isn’t as detrimental as using a stronger pad. If a polish isn’t removing what you want, you may want to look into a different polish vs. using a cutting pad.
