Hi.
I've wrote about this in the past, and will reproduce some of my write so you can understand why polishing after nanoskin/claying is so important:
I was working on a trashed 2013 GM Cobalt in Solid Black color. I've tried to make my softer and best claying ever to avoid any marring since I was not willing to make the paint looks even worse.
I've used fine nanoskin mitt, plenty of lube, my best 'anti-marring' technique, see some shots what happened:
Before shot when car arrived (under the sun shot):
After thorough wash and gentle (yet effective) fine grade nanoskin (swirl finder light greatly reproduces defects spotted under the sun):
You can see the marring on the hood (slight in between horrible other defects):
Apart from marring, I would not feel comfortable if letting you without any correction picture around this work...
Test spot on the hood
The rear side pillar that is on before pictures above, under same light
From slight light change in direction while inspecting for any flaw
More clay marring (plus defects) on passenger's side rear part, under swirl finder light:
Under work light (NOTICE HOW DIFFERENT LIGHTING SHOWS MARRING DIFFERENTLY)
Done.
The clay marring 'per se' went away after 1-2 passes... however, this paint needed almost 3 steps in every section to finish in an acceptable manner.
In conclusion, nanoskin marring may occur to some degree depending on paint, so it's good to always be aware of it's possibility.
It's ugly, but it's really easy to get rid of. Can't say the same about 'vandalism' cars suffers from 'cheap' (in quality, not in price) auto washes all around.
Hope that helps,
If I'm not going to do at least one fine polishing approach, I'll not clay / nanoskin. Everytime you use it, you will benefit from polishing to remove your 'decontamination' marks.
They go away REALLY EASY!, and the sum of Smooth Surface + Polished Surface (even if lightly) may give you stellar results.
- It's a lot more noticeable on black car, but it happens to some extent in any color, just more difficult to notice.
Hope that helps,
Kind Regards.
