K
Kappy
Guest
There are 2" squares of tape surrounding both of the holes behind the rear license plate on my car. The squares aren't aligned with each other, and one is so crooked it sticks out above the top edge of the plate, although you have to get down at eye level to see it.
The tape is extremely thin and can't be providing much protection between the plate and the paint. Does it serve a purpose- as in what's it doing there is the first place? - or is it okay to remove it? I tried to peel up a corner of the tape and it tears easily, leaving a lot of dried adhesive behind.
Thanks in advance.
Thanks in advance.
