Maybe the title should read:
"Why not dry with fine grit sandpaper?" :dunno:
The thing is, (as has been stated) microfiber towels, (whether they be traditional nap, or waffle weave), provide dust/dirt/microscopic particles a place to 'hide' rather than just sit directly on top of the VERY FLAT surface that an Absorber has.
I have 2 Absorbers actually, used them for years on cars that I didn't care about. Even now though they are great for exhaust tips, rocker panels, inside wheel wells, under the hood.... places like that.
As for chamois cloths, there are new synthetic microfiber cloths out these days that IMO work better than "The Absorber" as far as leaving embedded material inside the chamois. They can be washed and clean out better overall.
Would I dry freshly polished paint with them?
Uhhhhhhhh NO!
One thing comes to mind though about drying, and that is technique.
When you use a blower to remove most of the water that GREATLY reduces the chances of damaging the paint during the drying process. What I'll do, whether I'm using traditional waffle weave towels (
like the Korean units from Microfiber Tech) or foam core waffle weave's (
Cobra Guzzlers), or even 530GSM dual-nap towels (
again from Microfiber Tech) is place the towel gently on the surface and gently pat the back of it with an open hand rather than go about rubbing it all over the place. (
With the Microfiber Tech Korean towels I'll fold them for extra paddig and use one side at a time.)
I will NOT however use anything less than the above 3 mentioned towels. IMO a standard waffle weave is just too stiff, too unforgiving, too likely to end up with scratchs/swirls/RIDS. They are great for glass, just don't trust them on paint.
