the detailing shop here uses 4 steps in detaling...they told me they're using:
step1: compound
step2: cleaner
step3: glaze
step4: sealant
is the process correct?
These are kind of the common steps, I could get technical and dissect the words a little but that's not important because words and wording can be fuzzy...
There are two GENERAL categories of car detailing,
Production Work
A one-step product is used on the paint that will clean, polish and protect in one step
Show Car Detailing
This is where a multiple-step procedure is used and dedicated products are used for each step,
The basic steps are for multiple step jobs would be...
Compounding - To remove serious or the deeper below surface defects like swirls, scratches and water spots
Polishing - To maximize the gloss and clarity by refining the finish to a higher level after the grunt work is done by the compounding step
Finish Polishing or Jeweling - This is typically an optional step and whether it's done or not depends upon the price of the job and the person doing the work.
Protecting or Sealing - This is what most people would think of as applying a "Car Wax", in today's lingo people either use a wax or a paint sealant, they both do the same thing so you typically use one or the other. The purpose of a wax or paint sealant is to seal and protect the paint while adding the finishing beauty touch at the same time.
The Step 3 "Glaze" you listed could be what the specific shop you're dealing with refers to as "Finish Polishing" or it could be they really mean to "Glaze" the paint. Glazing is something that is typically done at body shops on fresh paint because typically body shops don't seal fresh paint until after 30 days of air cure and because typically body shops don't allow waxes and paint sealants into their environment because it can cause fish eyes in new paint job. So historically, glazing is done with water soluble non-abrasive polishes to add the finishing touch after wetsanding, compounding and machine polishing and the glaze is used to mask or conceal the swirls the body shop Technician inflicts into the paint.
A true professional quality multi-step paint polishing process to a car in neglected condition, that is a car that has swirls and scratches, should cost you around $200.00 on the low end and up to $500.00 to $600.00 on the high end.
This is for paint only, this doesn't include vacuuming the interior, dressing tires, and all the things most people associate with getting their car "Detailed".
The reason for this is because a true, pro quality show car detail is going to take one person from 8 to 14 hours if it's done in a single day.
A Production type detail job will include detailing the entire car inside and out but the only way a detailer can make money doing this is to ONLY do one thing to the the paint besides washing it because paint polishing work is time intensive.
Time is money...
Chemical costs and pad wear-n-tear are also cost factors that detailers have to take into consideration.
Just because a shop offers a multiple step process, that doesn't mean they do good work and the norm believe it or not is they don't do good work. You need to research the shop, (like you're doing), and make sure they do in fact know what they are doing.
See these two threads...
DISO = The Dealership Installed Swirl Option
The story of 3 H's - Horrendous, Horror Story and Hack Detailers...
More to come...
