Why you need to polish....
Mobile Detailer
Written on January 21st, 2013 by Joe
Why You Need to Have Your Car Polished.
Vehicle Polishing is one of the most misunderstood processes for maintaining your car, maligned as an aesthetic neurosis when in truth the process of polishing is an important and necessary bit of maintenance to ensure the health of your car. From maintaining the body of the car to preventing deeper grooves and damage by keeping a sleek and level frame, there are a number of overlooked reasons for why you need to have your car polished. The term ‘polishing’ is a misnomer in and of itself, used to describe a broad range of maintenance revolving around the surface gloss and paint of the car but failing to convey the greater importance of doing so. Polishing processes make up a substantial maintenance of compounds, glazes and paints, yet is frequently skipped by car enthusiasts who don’t understand that failing to properly polish your car decreases the longevity of its frame by allowing gouges, scratches and uneven surfaces to flourish and fester. This combination of maintaining appearance and overall frame health answers the question of why you need to have your car polished in two distinct ways, and fully understanding these distinctions is the key to respecting the process and putting in the due work in preparing to polish your car. If the paint work on your car is in good condition polishing is usually needed no more than once a month, but cars with old and worn-out paint shouldn’t necessarily be polished with more frequency, as incessant polishing can further wear out the paint. It’s more important for car owners to exercise quality over quantity, and make sure to do a thorough polishing job rather than compensate for a lack of thoroughness with an unhealthy frequency.
Maintaining the Look of your Vehicle
This kind of maintenance also rests on the eccentricities of the weather, as frequent rains, heat or cold can affect your car and consequently determine your polishing schedule. For example, drivers traveling through sandy, dusty environments will generally find a greater degree of degradation on their paint than would be readily apparent in calmer weather, and car owners that leave their automobiles outside as opposed to storing them inside a garage might require more maintenance as well, subject to the wear and tear of the elements. Use your common sense when determining your own schedule. Even incremental damage to your car is readily apparent to the naked eye, and once these factors are found out, the appropriate maintenance is only a matter of planning. Preparation is, as always, the key favor in successfully polishing your car, superseding the variables of coating, wax and finish. There is no price point and excess that can compensate for a poorly planned polishing process, and as has been mentioned, repeated polishes can damage your car and ultimately do more harm than good.
Polishing your Vehicle will protect its Value
Neglected cars diminish in value, and in extreme situations neglected and unpolished car bodies can negatively affect driving conditions by changing the aerodynamics with deep grooves and uneven surfaces. The proper planning for proper polishing involves removing any bonded contaminants on the surface of your car using detailing clay or tar removers before beginning the actual polishing process to smooth over any defects underneath the surface of the paint. Enhancing the surface gloss of your car keeps it smooth, sleek and new, and car care enthusiasts can’t afford to overlook the necessary maintenance of car polishing.
Related Articles:
Hand Polish Vs. Buffer for Cars
4 Essential Steps to Exterior Auto Detailing For Your Vehicle
Detailing Tips for Tire and Wheel Cleaning.
This article and many others can be found here >>>
Polishing your Vehicle will protect its Value. | Auto Detailing Blog San Diego
