Will Klasse AOI Remove Marring Introduced By Clay?
Canehdian
I didn't realize that you needed to polish after claying, and I don't have a DA polisher.
Will Klasse All-In-One remove the marring that was introduced by the clay?
It should...if you use a DA polisher. :D
{J/K}
IMO:
Depends on the severity of the marring from the claying
process; and: the type of applicator, pressure/downforce,
arm/hand speed, etc.
Come to think about it:
As likely the same variables, when using a DA polisher.
Klasse AIO contains no abrasives, so the product does not cut. Using on a DA, the pad might level out some marring.
no
You dont "have to", if after claying you desire a deeper gloss than polishing is required
