This is actually a multi-questions:
1. Does QDs have any cleaning abilities (i.e. Meguiars Last Touch/UQD/OID/FK425)?
2. Since QDs have some added benefit to their properties, would they affect bonding performance if applied just before applying sealant/nuba? I usually clean a lightly dusty car using QD then apply sealant/nuba 15-20 minutes after the remaining QD flashes out of the panel, wonder the bonding would still be ideal after applying QD, specifically for nuba
3. Referring to #1, if they own some cleaning abilities, then what would be the effect if we buff off some hard nuba/sealant using lightly mist QD? I usually do this on hardened LSP like Meguiars M16 or Migliore lineup since they tend to harden after a while, and in case of Migliores kinda impossible to have a buff off residues without the help of Meguiars Last Touch. If it cleanses the LSP then probably all the effort of applying LSP would go to waste
4. Same case & question to #3, but to eliminate streaking from LSP
Any kind of input will help....
Thanks
Thanks
