Will the LHR15 front housing fit the Duetto
Whitewater25
Member
Has anyone tried putting the front housing from the LHR15 on a Duetto? It looks like it might fit. I would rather have that front housing if it fits.
I'm also going to be to say no, bit possible since the shroud and everything under is the same minus the essentric and BP.
Very lil above the shroud is the same.. but could have same mounting points.
You're able to swap a 15/21mm essentric inside the duetto though.. just use the matching backing plate with whichever essentric you plan to use.
Makes an quick conversion ... just one backingplate bolt and 3 screws holding the essentric.
It's only a 34 dollar gamble if you want to try it.. unless you have both machines laying around
