Well, my house hunting has gone well into the winter, and i have come up with a more affordable way to remove salt from the car...
what you need:
car shampoo
bug sprayer bottle (the kind you pump up)
squirt bottle
1: I use megs hyper-wash, 1 oz per bottle, and fill to top, shake to mix
2: Fill bug bottle and pump
3: On one panel, spray with car wash mixture
4: Let the spray float down, lifting most of the grime
5: Once you think it has sat enough, spray top to bottom with bug bottle to rinse
this has kept me from the coin-op wash and in control of what touches my paint much longer than before... there is a chance of freezing and the wash method doesnt remove everything, but it reduces the stuff that will collect on the paint, and makes me cringe less... it also removes enough grime for me to safely use ONR when it is warmer... (when i use ONR, i spray with bug bottle as well to fully wet the surface and remove residual grime)
this method has also sparked a new desire to place myself in a new home sooner than ever...
what you need:
car shampoo
squirt bottle
