You are correct.
More from Pro-detailer Ivan Rajic on what causes swirl marks:
DRYING
"From my experience, next to washing, drying is the second most responsible for creating swirl marks. In fact, washing is in a way the most important part of drying because if a vehicle isn’t properly washed and cleaned, the drying process will surely result in quite a few swirl marks by dragging around left over dirt. Assuming proper washing is done, the right products and techniques are a must when drying in order to keep the paint as swirl free as possible. Cheaper towels of lesser quality tend to get hard after only a few washes, which leads to bad absorption and possible swirling. Pressure and technique are also greatly important. Pressure should be extremely light or none at all, simply enough to hold the towel on the paint to let it do its job. As for technique, the only way to all but completely eliminate possibility of swirl marks is to use to blotting method. Otherwise, wiping the paint even with little to no pressure can create swirl marks if something gets caught under the towel. Whenever I’m working on a car, I like to use Microfiber Waffle Weave Drying Towel and prefer to use the blotting method."
DUSTING
"Dusting is a touchy topic with many car owners out there. There are a few dusters that are highly recommended and work great for everyone and there are some that just drag dust around. I personally only recommend cleaning the car with a mitt while washing and I will leave it at that. Reason being, dusting can definitely cause swirl marks because you are dragging a duster across the paint finish trying to pick up dust particles. If you must use a duster, I would advise the obvious like keeping the duster clean and using it as delicately as possible."
QUICK DETAILER WIPE-DOWNS
"This is one of the most poorly advertised processes and products within the detail industry. There are numerous quick detailers sold by a few different manufacturers that encourage car owners to simply spray on and wipe off for a great shine and some protection. What they don’t tell you is that along with the shine and protection come some swirl marks and scratches. Similarly to, but much worse than dusting, doing a quick detailer wipe down is a process where dirt and dust is basically pushed along and into the paint with a towel. As you can imagine, if there is a good amount of dust on the paint, especially if the paint is soft, one wipe with the quick detailer and towel will easily cause swirl marks. This is regularly done at car shows and concours events, so ironically the cars are being damaged while at the same time being displayed as great pieces of machinery. To avoid this I would simply recommend avoiding any quick detail wipe downs unless it’s just after a thorough wash or wax application, so basically after the paint is thoroughly cleaned. Otherwise, swirl marks are just about guaranteed during this process.
If you must do the quick detailer wipe-downs, I would highly advise first using Optimum No Rinse (ONR) as a quick detailer to clean the paint before using other quick detailers to get the extra shine and gloss. This recommendation is based on my experience with an old client, who had to do 4-5 of these wipe-downs on his black limousine every day! He did so in order to have a clean, shiny car for each client, but as you can imagine it resulted in polishing every couple months. Every time I saw the car it was covered with swirl marks as expected, so I recommended he switch from the product he was using to ONR. Next time I saw the car, after about 1.5 months of daily ONR wipe-downs, the amount of swirl marks was only about 50-60% of how it was originally when he wiped it down with the other product, so it definitely worked very, very well."
