vincec
Member
- Aug 28, 2016
- 77
I recently purchased Wolfgang Über SiO2 Coating Wash and plan to try it out tomorrow when the weather warms to the mid-40's. Has anyone tried this product in a foam gun or foam cannon and how much did you add to the bottle?
I usually add about 1/4" to the foam cannon bottle measured up the side when set on a flat surface and fill just under half way with warm water. This provides enough soap mixture to completely cover two mid-sized SUV's in thick foam. I normally foam the vehicle then go over it with a microfiber wash mitt rinsing in a bucket with a grit guard after each panel. I use about the same amount of soap with the foam gun as well but spray each vehicle in thirds washing with the mitt in between since the foam is not nearly as thick and runs off too quickly.
Based on the reviews I wanted to try this coating wash to provide some additional winter protection until the weather warms and I can more fully detail the vehicles.
