Wolfgang 3.0 Sealant Review
Pats300zx
Active member
Today I finally had the chance to try out the new Wolfgang 3.0 Deep Gloss Paint Sealant. This is a huge improvement over the original version. I applied it on a 1999 Metallic Green VW Jetta via the UDM and a Sonus Blue DAS pad. The Wolfgang applied very easy with no streaking.
I allowed it to haze and buffed with a the new Cobra Miracle Towel. WOW..the flake really came out in the finish and it was so easy to remove. I am curious to see how it holds up durability wise compared to the older verison of Wolfgang.
Pros:
Easy to apply and remove
Removal is a breeze
Very crisp sealant look
Cons:
None.
I will post pics in my next Click and Brag on the Jetta detail. Overall I found this to be a great product and would recommend it.
Pros:
Removal is a breeze
Cons:
None.
Huge improvement in looks, ease of use??? Please clarify...
Both. I just looked at the car today and it had a chance to cure and it looks fantastic. Much more of a sealant look as compared to the original version which had a muted carnuaba look. Removal was a breeze. Although the original version was easy to work with, this one was even better. Later I found some areas that I missed around the taillights. Came back with a MF towel wiped off these areas off with no probs even after sitting for a couple of hours.
sounds like it is more crisp and reflective, common to sealants.
Thanks...I'm overstocked with sealants, but I might give this one a try later down the road...
Thanks, I'll give it a try!
Just kidding, thanks for the review.
