Wolfgang AIO - Topping with other waxes
Njohc
Hello,
Im going to be polishing my daily with Wolfgang AIO some time this week in order to prep it for the winter. I plan on using a Microfiber cutting pad, and then following it up with a microfiber polishing pad. After the whole process is done, Id like to top the AIO with either a spray wax (v07 since I have a ton of it) or Wolfgang Fuzion paste wax. How long after removal of the AIO do I need to wait to apply this top wax ?
Thank you
-Tyler
You can top it immediately after you polish the WHOLE car. If there was a waiting period, say an hour or so, you would have eclipsed that time while polishing, except for maybe the last few panels you polish. Just work in one direction; meaning, first wax the area you first polished, then move around the car in that order. Make sense?
Hey Tyler, so far so good. Make sure to perform a test spot with the mf pads to check the results. Do you happen to have any foam pads by chance? You may need foam to finish out with.
You can top the AIO as soon as you are finished polishing. If it were me, I would top it with the Fuzion Paste and leave the V07 to protecting the door jambs, wheels, etc.
Wolfgang Fusion is an excellent
"hybrid"-Wax/Sealant; but, I'd
rather top-off Wolfgang AIO with
Wolfgang Deep Gloss Paint Sealant
(WDGPS 3.0). Personal choice.
I do have foam pads. Using the microfiber pads was just a rough guesstimate based on how hard my paint is. Will definitely do a test spot and adjust accordingly. I kind of figured Id top it with the Fuzion paste wax, and then either use my AMMO Hydrate of v07 after every wash to keep up some type of protection.
Thank you guys!
