Wolfgang CQuartz compatability
JHartman
I'll be doing a complete correction on my black Lexus and would like to use: Total Swirl remover, finishing glaze and, as the LSP, Perfekt Paint Prep before using CQuartz as a final coating.
Does anyone know of compatibility issues between these product lines? Thanks all!
The correction an polishing sessions will be fine.
However if you are going to use CQuartz as the LSP, I would follow the manufacturers directions and use Eraser as your choice of paint prep.
I've tested Perfekt Finish Paint Prep with Cquartz and have not experienced any compatibility issues.
If you already have it, use it. If not, play it safe and go with Eraser.
Thanks all. I've already purchased the products and don't want to have to buy more unless it's absolutely necessary.
You should be fine. As long as Paint Prep is removing the oils, you're good. Do 2 coats of CQuartz if you have enough.
