does #21 or #26 leave a white residue on trim? I plan on taping but wondering for specific areas,
You'll want to remove tape before sealing. Whether you've done single or multi-step paint correction for instance.
Both don't need to get on trim, but can get on it if you wipe it right off. I don't have anything with a bunch of hard plastic trim that turns white though, but rubber trim I don't have any problems with. Just wipe as you go. Also with M21 you can leave it on anywhere from 15 minutes to 3 hours and it seems to come off just as easy.
In the interest of full disclosure, I mentioned earlier in the thread how I'd rather not use a WOWA sealant. One of the reasons is all the wiping of the paint with the applicator and a fear that applicator induced marring will take place. In looking at several microfiber applicators I have, they are ALL made of the cheapest microfiber towels you can buy. I actually have two green ones that were sent as freebies that match exactly the green mf applicator pads in one of my last orders.
With that being said, I washed my G the other day, just too dusty to keep wiping it plus I got caught with a little bit of wet road (about half a mile) the other day on the way home. (
Wasn't raining, but the road was still damp from a passing shower.) Decided I'd just put a coat of BF Crystal Seal on it, and instead of the regular pad, I just folded up one of the Costco gold's into a small pad and it worked like a charm. Much softer than the other pads, and a little longer nap to boot.
One thing I don't like about it (BF CS) now that it's cured a couple of days, is it is a LOT less slick and sexy feeling than Megs 21. It's actually 'grabby' feeling! Megs leaves the surface sensual and silky feeling, like sliding a satin top sheet off a bottom sheet. Not quite oily, but surely not 'grabby'.
I'll hit it tomorrow with some BF WD Polymer Spray and see if that helps the feel. Seems I remember that WG DG Liquid Seal wasn't
as 'grabby'. :dunno: Also have WG DG Spritz Sealant, but I'd be hard pressed to say there was much difference between it and the BF WD Polymer Spray.
I know that Megs 156 is slicker, and DG 951 is slicker than that. (Plus I keep a bottle of each that has been polycharged.)
