Wolfgang on Gel Coat?
Ray & Paula
Hi,
First, I'd like to know if a swirl remover can be used on gel coat? If yes, can Wolfgang TSR 3.0 be safely used? I have plenty of TSR 3.0 and Wolfgang Finishing Glaze. My polisher is a PC. My boat is in excellant condition with the exception of a couple small areas. Any suggestions would be most appreciated. Thanks, Ray
I have used standard compounds on boats before. It does work.
I would suggest to bump the speed to 6, use enough product and swap pads often as heat will build up quickly. I have used D300, 3M and Megs on a few boats and they all work fine
