Thanks....that answered a question I had as well.
Not to steal your thread but would the WG polish enhancer be a better choice than WG sealant then apply WG Glaze and/or Fuzion.
Trying to decide to go with the enhancer or sealant on a car with good/no swirl paint.
You can go straight to sealant... (Disclaimer) I haven't used the product but that's how these paint cleaners work. It's just like after you polish. The only question you might have is if your sealant is compatible with PPE. If it is then you go straight to it. If it's not then you may wash first. What I mean is if there are oils that PPE leaves behind it could lessen the life of the sealant depending on what sealant it might be. My bet is you should be fine.
For instance I use Ultima. When I polish I come back at the very end and clean the paint with Ultima Paint Prep Plus (no pressure) on a blue pad. The reason I do that is just to remove any oils the polishes leave behind, "prime" for the Ultima Sealant.
Basically if you are using a Wolfgang Sealant with that PPE then I'm sure it's fine. If you are using a different sealant then it's probably fine as well but it could affect the durability. Wash 1/2 a panel and seal the whole car and document it. We can find out if you see any differences.
