Wolfgang si02 Rinseless Wash
PeteT19640
Member
Hi I use this product as a waterless wash.
My question can I use to much of the mix, seems to take at least two wipes to dry?
Car is large.
My thoughts are the more I use the more lubricant.
Thank you
Car is large.
Thank you
Follow the directions exactly because that is how the wash was designed to work for maximum effectiveness. Adding more product beyond the recommended dilution ratio is just wasteful and changes the behavior of the wash. It doesn't improve lubrication or make it a "safer" wash if you dump way more in your bottle than required.
Thank you
I use the recommended dilution ratio in the instructions.
My bad, suppose to the amount sprayed on the car, I use a garden pump sprayer.
Don't overthink it. Lots of people use a bit more product. I wouldn't go crazy and just have fun.
Be wary though. The added sio2 may make upping the dilution ratio a nightmare.
Thank you.
Will keep in mind re dilution ratio.
Why could it be a nightmare because of streaking?
