Wolfgang Total Swirl Remover 3.0 Question than XMT 360....??
Rival
Hi, I am doing another hard clear coat car (vet) and just picked up Wolfgang Total Swirl Remover 3.0 Question, if i use an orange or yellow pad (yellow for bad areas, orange for everything else) will the XMT 360 be able to be my LSP or will i need to polish more before i go LSP....??
planning on using a white pad (all LC pads) with the XMT 360.
You will be fine. TSR is very user friendly. It's my favorite now!
I have hard paint also on a Merc. I found the TSR worked pretty well with the yellow pad, however with the white, which I started with, did not correct enough. I switched to Meguires D300, for the top layer of the car and the white pads leveled it perfect. Just giving you a good suggestion if the TSP is difficult for you. Soft paint and minor corrections it works awesome though.
with the 5.5 orage pad it was great on hard paint too. 5k speed, 15lb pressure, finished almost LSP ready.
the XMT 360 cleared up anything left behind. It was a great 2 step job and using the AIO allowed me to skip polishing out minor minor stuff.
