Wolfgang TSR versus Menz 203
bobble
Are these the same or very similar products? I only ask beacuse I have do our 08 MBZ C class soon and have about 3.5 oz of 203 left but have a sample of TSR. If I run out of the Menz (I only purchase stuff on sale and usually stock up but somehow did not notice I was almost out) could I simply finish up with the TSR. Only the hood and trunk have defects and I am following up with P85RD and then DG105 + 845 as an lsp combo. Car is Artic White, am I over thinking this because I should have enough 203 for this car.
203 is Power Finish? I thought the TSR was more closely related to SIP, but maybe I'm not remembering right.
Thanks for the chart, I had the Menz one but that one is way better.
So my question still stands if it looks like I could run out could I substitute a little TSR to finish up given that I'm following with 85RD before the last steps? 3 oz should be enough to do one midsized car (no roof needed as it has the panorama glass roof) but just want to plan ahead since I won't be ordering again for a bit, going on vacation for two weeks.
If you're following with 85RD on the entire vehicle, it shouldn't matter. If 203 is doing a good enough job correcting, I don't see an issue.
TSR doesn't finish as nicely as 203 (on soft paint as least) but its moot if you are following up with another polish
ime, TSR never cuts as much as SIP for my vehicles.
TSR = PF. That chart isn't totally accurate IME.
