Is this stuff used as a drying aid, or after the car has been dried?
Does that even matter?
I use it as a drying aid on ceramic coated vehicles when I wish to boost the coating with a ceramic booster. Heres the text I copied from a FB post:
I performed our Emerald Package on the Audi A6. The wheels, paint and glass had already been ceramic coated, so the car was very easy to wash. I actually applied a booster to the ceramic coated surfaces in three ways.
1. I added an SiO2 Rinseless wash to my wash solution to boost my wash and provide lubricity, providing an over all SAFER wash of the vehicle.
2. I utilized and SiO2 waterless wash as a DRYING AID to provide LUBRICITY during the drying process and lay down some SiO2 protection.
3. I applied a CERAMIC BOOSTER which will help to extend the life of the coating for up to 6 MONTHS!
If you need to MAINTAIN your #ShowCarShine you need to call 405-208-0999!
Here are the directions for the WG Uber SiO2 Rinseless Wash from the AG website:
"To make it waterless wash, at 1/3 ounce to 16 ounces of water. For a clay lubricant, add 1 ounce to a gallon of water. If you want to make it a detail spray, add 3 ounces to a gallon of water. And finally, if you want to add lubricity to another car wash, add ½ ounce to another soap. It’s basically a 5-in-1 product!"
1/3 once is approximately 9.85784319 milliliters. If you purchase the WG Uber SiO2 Rinseless Wash squeeze bottle it has a measurement of 10 milliliters on the reverse side of the OZ measurements on the fill cup of the bottle.
You can squeeze out two 10 OZ measurements into a 32 OZ spray bottle and then use that as your drying aid and waterless wash.
Sent from my SM-G975U using Autogeekonline mobile app
