flyfishindawg
- Oct 30, 2008
- 72
Simple question here; that is, can wool pads be used with DA polishers? I have a Megs G110 and want more cut than a yellow foam pad will give me. Thanks!
Are wool pads supposed to shed their fibers? I only used one once with a rotary on the boat, and fibers were going everywhere.
dang! a yellow pad is pretty aggressive though! i've made quick work of some pretty nasty scratches with my PC, optimum compound and a 4" yellow CCS pad.
From what I've read wool seems to work better via rotary. Have you considered a small 4'' pad? Or maybe a more aggressive compound. Which leads me to ask what are you using? and what are you trying to remove?
Thats my suggestion too, smaller pad..go with aggressive compound Megs #105 or the new #205 both have taken out some serious scratches and defects on several cars that I have done.From what I've read wool seems to work better via rotary. Have you considered a small 4'' pad? Or maybe a more aggressive compound. Which leads me to ask what are you using? and what are you trying to remove?
I keep hearing about these purple wool pads from LC. Can someone post a link? I searched the store here and couldn't find anything purple.
Thanks!
thanks!
