I save my blue bottle for dark laundry.ryandamartini said:classic blue bottle for me..![]()
Yep!kev1027 said:I didn't know it was laundry detergent either. So are you putting it in a spray bottle and diluting it? Then just spray on carpets and seats and scrub?
P1et said:Woolite is supposedly made for washing delicate clothing, like PANTIES!!!
But it sure works great too cleaning the carpets in my truck, hehehehe...
ltoman said:Ok P1let, I can't help myself....
WHY are YOU wearing PANTIES?????
roflmoa:applause:
Don't worry. I won't tell the wife.P1et said:Only on Friday nights Lauren -- HEHEHEHEHEHE!!!
Juuuuuuuuuuuuuuuuust kidding of course!!!
roflmoa:applause:
TOGWT said:Heated waterbreaks down water-soluble soiling faster as it reduces overall chemical usage because it reduces the surface tension of the fibre. Heat acts as a catalyst promoting quicker reactions between chemicals and the soil thereby minimizing dwell time.
To remove stains the surface tension that bonds them must be released, then the stain encapsulated and held in suspension to be removed. When cleaning a stain, try detergent and water first (6:1 solution Distilled water / Woolite ®) If this does not remove the stain, then try a stronger type cleaner (303'M Cleaner & Spot Remover or Folex Instant Carpet Spot Remover) once fabric is clean apply a fabric protection (303TM High Tech Fabric Guard)
I’m repeatedly asked which product is the best interior cleaner. There is no one-product answer, as the so-called all purpose cleaners (APC) do not remove every stain, different stains require different solvents to remove them.
Between these cleaners you should be able to remove 99% of stains occurring in a vehicle and around the home –
a) 303™ Rug / Upholstery Cleaner & Spot Remover
b) P21S Total Auto Wash
c)Woolite® Heavy Traffic Carpet Foam
d) Hoover Deep Cleansing Carpet/Upholstery Detergent
e) Folex Spot Remover
Classifying stains-
a)Organic stains- these include proteins and fats, body oils, mould yeast, bacteria, bugs and carbohydrates. Most of the stains found in the vehicle interior are of an organic nature and require an alkaline type cleaner. Some organic stains (i.e. blood, vomit, urine) should be removed with an enzyme type cleaner and a disinfectant applied to the area
b)Non-Organic stains- mostly found on the exterior of the vehicle, hard water scale (calcium) lime deposits, Road tar, grease and oil film, and require an acidic type cleaner.
c)Petroleum soils - substances that do not contain water, nor are they miscible, these soil types include, motor oils, and crease and road tar, and require a solvent type cleaner.
Stain Types-
a) Water Soluble Stains-These stains can be dissolved in cool water or loosened with water based cleaner, coffee; soft drinks, cocoa and chocolate are good examples.
b) Oil soluble stains- These are stains that are comprised of oily or greasy substances, which include cooking, oil from fried foods and suntan oil.
c)Combination Stains-These stains contain both water based and oil-soluble properties. Cleaning these stains require treatment with a petroleum solvent followed by water based cleaning solution.
d)Unidentifiable Stains- Sometimes stains cannot be identified. Treat these stains like a combination stain. Clean with a petroleum solvent followed by water based cleaner.
{Experience; [and the correct information] can be a great teacher}
Classifying stains-
Stain Types-
supercharged said:Huh? you wear those on Fridays?![]()
AL417 said:Your posts are very direct and extremely informational. I'm just curious where you dig up this almost encyclopedia-like helpful info.![]()
