DA - Rotary -Microfiber Cutting - Lightweight - Full Size, 21mm throw - Forced Rotation. Even with massive forum like autogeek it`s COMPLICATED. It is. Don`t need to hear that it`s not.
Started detailing bussines and for some 5 months I corrected a lot of cars with "I`m not pretty sure but it is FULL SIZE rotary" it`s not Makita, or dewalt, it dosn`t have any known name and in the beggining I made some small mistakes but they were some pretty thin pannels, or edges, it was maybe 20% my or rotary problem, then in the last months I think that I don`t have much of problems, I sometimes fly with that machine (not really I`m educated and I work in small panels), it`s very easy to control.
The problem.
I`m very interested in dual action machines, Rupes, Flex but only when I see how slow arm movments you need to do with them I say a big noo (I want quality, but most important is productivity). And then it doesn`t work very well in edges, you need to keep this way for spinnig, you need to keep flat, nooo I don`t have this kind of problems with my heavy dutty unknown rotary.
Ok I need quality, precision and after all I readed until now and because it need`s to be somehow quicker not slowly like DA`s, and because I masteret my havy dutty rotary, I wan`t a precision rotary which in this case is Flex PE 14, don`t know what the differences will be but my mind is in that one PRECISION, and I know from here that the best way is to have FULL SIZE and LIGHTWEIGHT ROTARY of course all for CORECTION STEP.
Then why Flex PE 14-2 & Rupes Duetto 12.
What I will offer in my bussines..? Correction and One Step Polishing
I`m not sure that even with Sonax Perfect Finish and Flex PE (for one step polishing) will be possible to finish hologram free, in the official video they describe that you will have hologram free finish which i dont belive. If this was possible I would not need Rupes 12. When I do Corrections I use FG 400 for correction and follow that with SF 4000, this way I`m sure that the finish is hologram free even with rotary. And for one step SF4000 many times it`s not enoght.
And to sum it up.
For Correction my havy duty rotary and FLEX PE, the test spot will give me the answer. Not to forget 3inch pads with FLEX PE.
For One Step polishing Duetto 12, I want duetto because I think is more comfortable specialy in vertical panels, I think I will manege it better. Anyway I will use just for polishing not correction.
Feed back please.
The problem.
And to sum it up.
Feed back please.
