swanicyouth
- Mar 3, 2011
- 9,388
I bought a bottle of Wurth Screen Wash Additive from AG to use during the upcoming winter.
I searched all over the Internet prior to purchasing to come up with a recommended dilution ratio to see how many bottles I needed to buy to last through the winter. I could find no info anywhere on the dilution, so I figured I would start out with one bottle.
Bottle arrived and has the strangest dilution chart I have ever seen. The chart is based on what state (and sometimes what county) you live in to come up with a recommended dilution so the mixed product will be VOC compliant in your area
Now I obviously understand the different dilutions, but have no idea what dilution I should use. The bottle is 8oz. I really don't care if my mixture is VOC compliant, as I don't think the police are randomly testing washer fluid concentration yet. The dilutions range from 1:1 to 1:64. Since the bottle is only 8oz, 1:1 doesn't get you very much washer fluid. I can't imagine 1:64 would be much different than water. How can they recommend so many dilutions to do the same job? Also, they give no info on what dilution freezes at what temperature. I would like to use this stuff so it doesn't freeze over the snowy winter.
It would be nice if it said that you would need multiple bottles to make a gallon of mixture in the product description, as every recommended dilution (except California at 1:64) requires more than one 8oz to make a gallon of solution (size of most washer fluid tanks)
Does anyone have any experience with this stuff? Is it any good at say 1:15 ( about 8oz/1 bottle to a gallon)
Thanks.
Thanks.
